i think you removed the older one and need to install cartridge
follow the steps below
1. Make sure that the power is turned on, and open the Paper Output
Tray.
2.Lift the Scanning Unit (Cover), then hold it open with the Scanning
Unit Support (on the right side)
3.automatically The Cartridge Holder moves to the replacement position.(don't force it manually)
if it moves to right then close and open scanning unit once again
4.Pinch the tabs and open the Ink Cartridge Locking Cover.
5.remove protective cover in your new cartridge
note:do not touch electrical contacts and print head nozzles
6.place your cartridge on correct slot(color on left,black on right)
7.push down locking cover until it clicks,
make sure that locking cover is not tilted
8.Confirm that the Ink Cartridge Locking Cover is closed correctly.
9.Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support
back to its original position, and gently close the Scanning Unit
(Cover).
i hope this will solve your problem
regards,
cseian
