SOURCE: motion drive belt on craftsman riding mower
there is no adjustment..it is set by the spring that engages ur drive belt....
SOURCE: drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
SOURCE: Hi, Just replaced the drive belt on a Husqvarna
My name is Dane and I am going to help you solve your problem.
I looked up your mower and I believe you should be using drive belt# 5321701-40. That is a 112" belt. Here is a link to the parts manual and a drawing of the belt routing. As long as that is the belt you have, and replaced it correctly it should be fine. You are correct, when you put the mower in gear, the pulley system will put more tension on it.
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2003/HIPL2003_1063048-61.pdf
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Testimonial: "Thankyou Dane, You are a true proffessional!"
SOURCE: Drive Belt routing for Scotts Riding mower
I have to replace the belt part number m124895 on a Scotts riding mower.I need the belt configuration,since i bought it used.
Please help
