yes there is its prob clogged make sure that the coils are clean along with the filter. thanksyes there is its prob clogged make sure that the coils are clean along with the filter. thanks
You can't post conmments that contain an email address.
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
The smallest retail AC unit will cool down a 110 sqft room if...
1. It is installed in a way as to dump heat outside... 2. There is actually cool air coming out of the AC (it is working)... 3. The windows and doors are tightly closed... 4. There are no major drafty leak issues (i.e. hole in a wall)... 5. You're not adding substantial heat energy into the room (such as having 10 sweaty fat men eating food while watching Super Bowl on a 56" LCD TV)... 6. The room has at least minimum insulation (the walls are not just plywood)... Seriously, if HEAT is leaving the room by way of the AC, the room temperature HAS to decrease, unless HEAT is being added back into the room in some way. This is basically the 1st law of thermodynamics.
The AC evaporator/core condensation drain tube is located on the passenger side of the fire-wall towards the bottom of the fire-wall, (it resembles a heater hose that is coming off from the fire-wall and it connects to nothing, and it is just to drain the AC condensation) and it is easily viewed from under the vehicle. Use long pipe cleaners folded in half to clean out the AC drain, and be very careful that the AC evaporator/core, or the heater core is not damaged from using any hard or sharp objects to clean out the AC drain.
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
How do you access the drain to unclog it?
