SOURCE: Wenzel Monarch Tent instructions
Wenzel does. They e-mailed me one for a different model that I bought on eBay. They're website doesn't offer any help but they were very helpful when I called!
1-800-325-8368
SOURCE: wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
SOURCE: recently purchased tent with damaged
Here is a PDF with the assembly instructions for your tent as well as a PDF with instructions on how to care for your tent.
Assembly instructions for Eureka Tetragon 1210 8 man Tent -http://store.eurekatent.com/media/document/TETRAGON121009IM.pdf
How to care for your tent -
http://www.eurekatent.com/detail.aspx?id=47
regards,
Tony
Black and blue together from the fan hook to black from ceiling. White to white. Green to tan. That is “if” the house is wired according to Hoyle.
