I press power and it clicks,and red power light flashes as usual, but nothing turns on. it usually clicks and light flases for a few seconds and then you can hear it power up and picture is there.
It has been taking longer to power up and one night it just went blank.
I pressed power and it clicked off. I pressed power again and it clicked and red power light flashes,but it does not have any power up sound,and wont display picture or sound.
Sony 35" Trinitron Mdl# KV-35S45
Thanks for any help
Sounds like it could be the flyback transformer, time to leave CRTs and go to LCD, LED or Plasma.
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
