Samsung CLX 3160fn All-In-One Printer Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Default login for samsung syncthru
Just wondering what the default username and password is for samsung syncthru 4.5
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
74691
Points
43
The username is
Admin
Password is
sec00000
martin_hohen
Level 1:
New Friend:
  • Posted on Nov 11, 2012
martin_hohen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
74691
Points
Note: Username is *lowercase*, admin instead of Admin :)
Mohan Kumar
Level 2:
Sniper:
  • Expert 98 Answers
  • Posted on Jan 20, 2015
Mohan Kumar
Expert
Level 2:
Sniper:
Answers
98
Questions
0
Helped
111879
Points
283
The username is admin
Password is sec00000
Some times check for pending services to restore them to make it work.
2helpful
2answers
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Help me with my wep key please
2helpful
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset password of DGS3627 from console
1helpful
New password wifi
Lost my password and cannot connect new netbook
hi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  • Step 2reset-password-linksys-router-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a02/2p/6m/reset-password-linksys-router-1.2-800X800.jpg'); }); Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • Step 3 After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • 0helpful
    SmartEther SH2224S Password
    username : samsung
    password : samsung
    They are case-sensitive.
    Top Samsung Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Norman Weimar
    Norman Weimar
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
