Geneve 14K Gold Ladies Diamond Mesh Watch Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Came from service merchandise in the eighties. How do you replace the battery? Is it through the crystal or from the back It's a 14kt gold mesh watch with diamonds around the crystal and a saphirre on the stem
  • merryiam Aug 12, 2009
    It's not exactly like this one and there is no clip in the back.
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Aug 11, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813887
Points
13579
Your watch has a clip-on back. Open it and change the battery.
I have a gold finish Jules Jurgensen ladies watch with a broken butterfly clasp,how can I get the clasp replaced?
Jules Jurgensen Watch Repair - Free Shipping & Estimate
Ad·www.watchrepairsusa.com/
Restoring Excellence To Your Watch. One Year Limited Warranty. Genuine Watch Mfr. Parts. Expert Craftsmanship. Free Insured Shipping. Services: Crystal Replacement, Watch Repairs & Service, Watch Restoration, Pocket Watch Restoration, Seals/Gaskets, Tune Up.
Common ServicesNo Problem Too Small
Tune Up, Overhaul, Battery & More
FAQsGeneral Questions
Shipping & Security
Jules Jurgensen Watch Repair, Overhaul/Movement, Crystal ...
https://www.totalwatchrepair.com > pages > jules-jurgen...
Maintained stock of Jules Jurgensen name parts ... Vintage Quartz Square Women'S Watch Black Band For Parts/Repair, #7730 Women'S Watch Clear Crystals ...
BULOVA ACCUTRONE E66831 M8 14KT WIND STEM AT 4 OCLOCK NEED TO KNOW IF IT IS WORTH MORE THAN THE GOLD CASE THANKS
The M8 indicates this watch was produced in 1968 and probably sold for 250-350,this is a tuning fork watch and they are highly collectible and worth up to twice the value of the gold or more depending on the model and condition
1helpful
I have a Police Phalanx watch, black and rose gold effect. The glass has a couple of scratches and one of the rose gold markers has come away at the 10 o'clock position. Would it be expensive to repair...
If the crystal of your watch is made of plastic, it may be possible to buff (or pay a jeweler to buff) it. Buffing a crystal is very inexpensive--sometimes free--and may eliminate the scratch, or, at the very least, greatly reduce its prominence. However, glass crystals cannot be polished in this way; the only way to fix chips or scratches is to replace the crystal, which can run anywhere from $15-50+, depending on the type of crystal and amount of work required to replace it and test for proper water resistance. Replacing the mineral glass crystals on some diving watches can be very expensive.
Markers on a watch dial are ordinarily stuck on with little pins and/or a dab of adhesive. If the detached marker is still in the watch, this is ordinarily a fairly simple repair. The watch would be opened and the movement removed. Next, the jeweler would carefully place the marker back into position, probably adding a tiny drop of glue to keep it in place. A job like this can cost as little as $25, if it requires no replacement parts and you take your watch to a place that does a lot of watch repairs, as opposed to a general jewelry store that has to outsource the repair to a wholesale workshop.
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
1helpful
I am a retail jeweler. We broke a cust.'s crystal when changing a battery. Need help in getting new crystal. Lds. 14kt,rect. milor,Italy. Please help
This is hard one. First advise is to contact manufacturer. If no success there, then you have to find out any watch repair shop with watch glass cutting services. I used to order obsolete watch glasses to cut over here in England, so, should be similar service in USA. Last and most expensive thing is to buy KRONOGLASS cutting machine, but you will be able to cut watch glasses in the future and provide this service yourself. Not much, but at least you have an idea where to look for. Rate me, plz.
How to replace battery in men's geneve 14k gold watch must remove crystal is it tricky?
It is not usual to remove the crystal of a watch the replace the battery. All other watches I have come across need the back to be removed.
I suggest you take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 22, 2010 • Watches
What can you tell me about a man's 14kt gold bulova watch with serial number 8317027?
Serial number does not tell anything at all, just the count of watches that have been produced. I need Model name, all the writings on case back and description of watch itself to the smallest detail.
6helpful
2answers
What type of battery do I need for a Rado watch (111.0322.3) - thank you.
Examine the markings on the battery. It is likely to be a 1.5-volt Silver Oxide or Alkaline battery. It doesn't matter which one you use, although the Silver Oxide battery can handle heavier energy-consuming loads, such as a multifunctional chronograph. It can be purchased from amazon, here: watch battery 1 5V silver oxide 357 SR44 SR44SW 10 pack. I hope this was helpful. Cheers
Simon
4helpful
Can't open Geneve OGW154 gold wrist watch to replace the battery
You are right, this type of watch can be opened by lifting crystal and extruding the stem. As for lifting the crystal you need a specialized tool, there is no other way then to go and find your nearest watchmakers shop. If you will try to lift the crystal using knife or any other unspecified tool, you will damage the crystal. Even if you will be lucky enough to get it out without any damage, you will not be able to fit it back, because the watch crystal setting tool reduces the crystal diameter for easy fitting.
Best solution for you is to see the watchmaker and ask for help.
Do not forget to rate, please.
Top Geneve Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Geneve Watch Expert? Answer questions, earn points and help others
