Apple iPhone Smartphone Logo
Posted on Aug 11, 2009
How to put sim card to the iphone? - Apple iPhone Smartphone
Anonymous
Level 1:
  • Contributor 6 Answers
  • Posted on Aug 11, 2009
Anonymous
Contributor
Level 1:
Answers
6
Questions
0
Helped
17904
Points
25
SIM card slot is in top of iPhone. From iPhone Manual:
If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
Install the SIM card:
1 Insert the end of the SIM eject tool into the hole on the SIM tray.
Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 10, 2009
SOURCE: Dear Sir, I have a Apple iPhone Model No. - A1203,
how can i activete my iphone healp me sir please!!!
A
Anonymous
  • Posted on May 09, 2008
SOURCE: iphone sim card problem
when in download the apple software guide from the internet. the next time that appeared on my iphone is simcard invalid . then an arrow saying emmercnecy call. theres no network. can u provide me solutions for this?
Anonymous
  • Posted on Dec 26, 2008
SOURCE: apple iphone.where abouts do i put my sim card in the iphone?
Use the supplied tool or a straightened out paper clip to eject the sim tray in the top of the phone. There is a tiny round hole in the top of the phone that you gently push the tool(or paper clip) into to eject the sim tray. Load your sim card and slide it back in and you're done!
Good luck,
Anonymous
  • 32281 Answers
  • Posted on Nov 26, 2009
SOURCE: iPhone SIM Failure
The phone is locked to Apple and needs a Security code to unlock it.
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for “Security unlocking code”.
Anonymous
  • 5 Answers
  • Posted on Dec 20, 2009
SOURCE: changing sim in iphone cause overheating and rapid battery drain
it is the sim card brother not the charging jack k you must upgrade your iphone version to use the simcard again and prevent rapid battery drain k. or you can change sim either. k
Unlock sim card error from Iphone 7
If you get an alert about the SIM card in your iPhone
  1. Make sure that you have an active plan with your wireless carrier.
  2. Update your iPhone to the latest version of iOS.
  3. Restart your iPhone.
  4. Check for a carrier settings update. Go to Settings > General > About. ...
  5. Remove your SIM card from the SIM card tray and then put the SIM cardback. ...
  6. Try using another SIM card.
https://support.apple.com/en-us/HT201420
How to put in the sim card
Please let me know the model and manufacturer of your mobile device as us varies from model.
for Iphone and smart phone with side sim slot:
. How to Put SIM Card Into an iPhone
Vodafone uk
No The sim card for the older models is not the same size as the new iPhone 5. You can take your old sim card to your provider and they can make you a sim card to fit your new phone.
My iphone cannot detect sim card after fall down, no service at all although I took out n put in my sim card for many times, help~
You have damaged your iPhone or your SIM card.
If you have another phone, you could test your SIM card by putting it into it. If it works, then it's likely an issue with your iPhone. If you can borrow a friend's SIM card, you can try putting that in your iPhone. If it works then you know you have a problem with your SIM card.
In either case, you should talk to your service provider to see if they can repair it for you.
23helpful
3answers
Where to insert sim card in iphone 3gs
At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
Put your sim card in the tray and put back in the iPhone
1helpful
2answers
Changing sim in iphone cause overheating and rapid battery drain
Apple iphone.where abouts do i put my sim card in the iphone?
Good luck,
Iphone
this is what you do
  1. get a unlock card Click Here
  2. get a Verizon Sim card click here
  3. Switch off 3G network: Setting---General---Network---Enable 3G---Off
  4. Turn off the iPhone 3G, take out the SIM tray, place the Unlock Card and the SIM card on the SIM tray, put back the SIM tray into the iPhone
  5. Turn on the iPhone
    There is NO NEED TO CUT YOUR SIM!
  6. Just Plug & Play!
2answers
2 Problems..Sim Card Problems
Well, first off, an iPhone won't work at all with a T-Mobile SIM card. American iPhones are locked to AT&T's network -- only AT&T SIM cards will work in them.
As far as activating it with AT&T, make sure that the iPhone isn't connected to the computer while you install iTunes. Once iTunes is installed, connect the iPhone to the computer and iTunes should launch automatically and begin the activation wizard. Just follow the instructions on the screen and answer the questions.
1helpful
5answers
Iphone sim card problem
i put the sim card into iphone is dont work
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
