Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
