SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
SOURCE: I have an old Kenmore sewing machine and after
The motor is probably a YDK, what you need to do is take a drawing of the plug on the machine and go to your sewing machine shop and you will probably get one.
Testimonial: "thanks"
SOURCE: Kenmore 158.1703 sewing machine - needle not going up and down
The machine sounds like it has threads caught in the bobbin area thus locking the machine up. Check in there and maybe you can pick them out with tweezers. They may need to be 'softened up' with a little oil before you can get them out!.
also Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew.
------This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
