If it overfills and drips, look for an
adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water
inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze. You can take the water
line off the valve and watch to see if it drips.
