SOURCE: Xbox 360 won't read a certain game
If you have the original X box CD's it will work fine expect when you have issues with region code.PAL NTSC are the two format a game can work with.so if you have NTSC formated game TRY a PAL version.it may work.
else clean your lens and try inserting a new CD of that GAME.
SOURCE: War Front Turning Point in Windows 7 cannot find the original cd
download War Front Turning Point patch .this patch can running on any system include win7.This patch did not need original CD just Copy over the cracked executable located in the Crack dir on the DVD to
the \Run dir of your installation directory.
You can download from patch.ali213.net/showpatch/5004.html
This is chinese web site
Patch is 10.8MB. I'm not sure can mail if somebody need it.
SOURCE: how to play with USB
Was there even USB when DirectX 7.0 was released? I guess so. Ignore it and install anyhow (since DirectX 11...14 are in the API of newer OS than Win98) or pick some drivers that don't require 18-year-old Microsoft bundling.
The company's drivers are at http://www.qhmpl.com/drivers.html (with yours at the bottom, I think) and there are probably better substitutes; in fact, I kind of expect that current Linux and Windows versions have drivers built in so you could just plug in the thing and have a working controller, force feedback controls et al. But maybe you need that ol' thing.
SOURCE: I have a Motherboard MSI 865PE Neo3 MS-6728
be sure if you computer and the installer is the same as 32 or 64 bit.. check your computer and your installer.... be sure you have updated version of your motherboard..
