You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Open the fuel valve ( at the back near the spark plugs).
Pull the choke knob ( SB side at the lower front of the motor)
Set the throttle handle in 'start' position ( abour 1/4 of the travelling way from SB to Port)
Pull the rope starter.
Should start easily.
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
