Printcopy.infohttps://printcopy.info > code=C-2402
Code: C-2402; Description: Erase lamp (EL) connector slip-off abnormality. - When EL turns ON before starting an initial charging, EL abnormality has been ...
Hey there, I had the same error code on a diagnostic scale from SilverCrest. I simply opened what I could, removing the plastic around the "feet" and then gently blew with an hair dryer inside. It seems that some sensor detects humidity so it fixed it for me. Took two minutes top. Please avoid buying new things as soon as there is a minor issue, let's save the planet !
Erase Lamp for Magenta drum not detected, 1st check the connection. If not swap lamp with different color if code changes then lamp is bad. if not board$$$$$$$$$$$$$$$$$$$$$$$$$$
There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and yes, we're looking into it. Stay tuned for updates.about 1 hours agovia webSonyPlayStation
