I need to know the height with and without the hinges
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
SOURCE: Fridge Area Light Will Not Turn Off
Yes unit was built by LG. The light broplrm is most likely the motherboard along with the light socket assembly that would have to be rreplaced. There is service information that the repair should be cover by an extened warranttee from the manufscture. The service flash sf46-515 indicates this and was recently put out. call Sears for service. Please note: recheck your model number as the one covered in the service info ends in the number :"one" insted of a "0"
SOURCE: trouble locating model numbers
i put your model number into the system its here, what did you need? you want to replace the refig with the same refrig??? if htat s the case take your model down to the sears showroom and the salesman will be able to locate the latest year model number for you. the number you have is probably a few years old they have moved on to new numbers,possible same dimensions just differnet numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=Bgl2MEGpgV3YgMXSX1xt+w**.shcapp3005?modelNumber=106.53603202+&pop=flush
SOURCE: find common dimensions of refrigerators, height, width, depth
There's a zillion makes and models of refrigerators with new one's coming on the maket all the time.
There is no standard fridge manufacturers must follow.
When I find a bad machine, and the customer want's to replace with new, I advise them to take the width and height of their opening before shopping, or be willing to remodel.
Best advice I can give you is plan the refrigerator opening for the worse case scenario on all your rentals.
As a general rule, refrigerators are becoming larger, and probably will continue that trend.
