Lands Phones Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I keep getting a message of unauthorized charger when I plug in m
Unauthorized charger
  • Official Brand Answer 3,100 Answers
  • Posted on Mar 13, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685032
Points
13487
Third party chargers don't work or if you have a non Motorola battery.
Mark
Motorola Support
Anonymous
Level 3:
  • Master 582 Answers
  • Posted on Aug 10, 2009
Anonymous
Master
Level 3:
Answers
582
Questions
0
Helped
238785
Points
1711
IF THIS CHARGER IS AN AFTERMARKET IT MAY NOT WORK WITH THE PHONE
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
2helpful
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
2helpful
Whenever i plug my charher into my motorola razor it says unauhorized charger.
The "unauthorized charger" message is hence telling you that the power
output of your charger is significantly lower than a Motorola charger
would provide. It may or may not still charge the phone, you'll have
to try it to see. If it does charge the phone it will take longer to
do so than a higher power charger would.
Hope this helps. =)
17helpful
9answers
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
change your battery and charger. tnx
My motorola w755 stopped charging
Is it saying "Charging" when plugged in?
Could be the wall charger.
4helpful
"Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
2answers
Battery charger
I'm not sure what the problem is with your phone, but this happened to me with another Motorola phone and it turned out to be a battery problem. You can try another charger, which might work for some time before you get the same result, but I believe you will need to replace the battery. You can try calling Motorola and checking to see if they will give you a discount on another battery. I've had several Motorola phones give me this same message and most of the time it was only infrequently and resetting the phone and reinserting the charger worked, but if it persists, try the battery.
3answers
V3 Mototola Razr Phone Freezes and charger won't work
unfortunately the phone needs to be reflash but this will delete all information on the phone.
So take the phone to a mobile service center and have that done.
Motorola razr wont charge
try to do a master reset/ have the mobile charger usb port service
Top Motorola Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
