My Navman 7100 VHF Radio powers up but I am unable to receive or transmit messages. Antenna is slightly bent after comint in contact with overhead rope. Any suggestions as to what might be causing this malfunction? Someone suggested the squelch function could be malfunctioning.
Any suggestions would be most welcome.
Kind regards,
Thomas
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
