Karcher 2500 PSI Pressure Washer Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pressure washer with 5hp Honda will ONLY run with choke on
Then stalls with choke off...? I did notice some oil in the air filter housing. Spark plug looks fine, oil level is normal. I'm thinking run it until it actually does choke. Anyone, anyone? Thanks!
Anonymous
Level 2:
  • Expert 174 Answers
  • Posted on Aug 11, 2009
Anonymous
Expert
Level 2:
Answers
174
Questions
0
Helped
112308
Points
430
It sounds like it has been tipped or too much oil has been put in. This would explain the oil in the air filter. First check the oil level. Then you need to clean the oil out of the carburetor. It is dirty or plugged and that is why it only runs when choked. You can try a spray-in carb cleaner but the best thing is to remove it (if you are handy enough) and soak it in varsol for 24 hours. Good luck
2helpful
I have a wood splitter that has a honda GCV160 5HP engine, when I choke it to start, it does find, but when I push the choke in, the engine will not run smoothly, it acts like it's not gettingg en
Sounds like debris in the carburettor. The carbs on these are relatively simple things which come apart easily. Check for debris or water in the float-bowl, and ensure both your idle and main jets are clear and you can see daylight through them.
2answers
Honda pressure washer 5hp will only run with the choke on. Was running fine for about 1 hour
The problems you describe are usually indicative of a blockage in the fuel system somewhere in the carburator or a damaged gasket that's letting in too much air. With the choke on, the vacuum in the carb goes way up and forces more gas through. Remove the carb and check the gaskets and insulator if it has one. Then check the float bowl for debris and blow out all the passages in the carb.
Sep 16, 2012 • Garden
1helpful
Honda 5hp engine only runs when choked. When choke is pushed in the engine shuts down. Pressure cleaner was running fine today for 90 minutes. Then the engine stopped. I was able to restart it for a...
Hello
You may have a clogged main jet in the carburetor, remove the engine shroud to expose the carburetor, the carburetor will be held on in most cases by tow bolts and then a basket underneath, remove the carburetor and flip it over in a rag to catch the fuel, then remove the screws holding the fuel float bowl on, carefully work the bowl loose to avoid tearing the bowl gasket, if you do damage it you will need a carburetor repair kit. Once the float bowl is removed remove the floor and the needle valve at the fuel inlet, set them aside, using a can of spray carburetor cleaner spray the inside of the carb and then blow through the jets with compressed air to dislodge the dirt (this is a must) that is obstructing fuel flow and causing the lean stall out, reverse and reinstall you should be good to go.
1helpful
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
2answers
I have a excell 2600 honda 5hp gc 160.It has not been used for over a year. I empted the old gas out & put in new gas. It will start but when I push the choke in it shuts off.
A couple of things....
Clean the air filter and make sure it is dry.
Check for any springs that have come off of the linkage.
With compressed air, blow out the carburetor.
Clean and clear out the fuel tube from the tank to the carb housing.
Be sure you have proper oil level.
Out of what you have said...it is something in the carburetor....probably needs a flushing with air.
Give it a try and post back!
3helpful
2answers
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
2helpful
2answers
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
2answers
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
15helpful
4answers
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
