Not clear when you have white lines. While looking on the screen or really on a image. Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen. Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Sound like a problem with your LCD screen, related with the CCD Image Sensor; since that you can view mode and setting displays, isnt the LCD screenviewer.
The CCD Image Sensor isnt a job that you can do it, I suggest visit your techinician service or apply if has underwarranty.
If lighting did strike, you would be suffering power supply problems, due to a power surge from the strike.
The problem sounds like it could be related to the LCD panel becoming faulty or if your able to test inside the unit with a multimeter, you can measure the voltages from the printed circuit boards, especisly those suppling power to the LCD panel as well as the Logic PCB, A small printed circuit board you will find either attatched to the LCD panel. I hope this helps.
Good luck.
Hi, It is problem of lcd screen that will be replaced to get correct picture view. Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself. Let me know if you need part number of lcd screen for DSC-S930 camera. Thanks.
i was taking picturres with my canon A470 digital camera and when i
review the pictures that i take, the pics were very bright that you
cant view well the pics. what is the problem with it? it just suddenly
happened like this.
This is a common problem with all LCD screens without anti-reflective coatings.This is normal. Increase the brightness of LCD while shooting in the sun. Internal memory normally takes only a few images. This is normal. Use a memory card to shoot more images.
Have u tried switching the view from and eyeview(viewfinder) to LCD while viewing pictures. Sometimes we forget it and panic. Hope it helps. Good Luck.
Yep the percieved advice is not fixable do to cost and the rapip advancement of new models
If it is out of warranty - the maker may offer swap out exchange for a reasonable price.
Try their website
