I am replacing the wear ring and prop on my 2009 seadoo wake Pro, however I can not get the wear ring to go in place.
SOURCE: What causes premature wear in the rings and bore of BMW K75s?
the K75 has very reliable engine .. its unusual for it to fail in this way .. the frozen rings would suggest overheating and thats possible if the radiator fan fails (that happens often before your 80,000) .. many of the pre 1990 k75s would smoke after storing for awhile .. that was a ring gap positioning problem .. that was corrected in newer models .. the smoke however would not have damaged the cylinders .. maybe in the extreme could foul a plug .. is it possible that someone put something in your gas tank ??.. or could it have been run without oil/water or perhaps the wrong type oil (like transmission fluid) ... that engine should have lasted longer than most cars .. nice smooth bike ..
SOURCE: spa motor making a rattling noise. Is it bearings
It's impossible to tell without first checking the condition of the wear ring.
I have replaced a couple of wear rings that had completely worn out and broken into 2 pieces, these made the pump noisier.
My advice would be to remove the end plate and take a look, if you cant see any major wear, remove the impellor and turn the motor shaft by hand to feel/hear the bearings.
Kind Regards,
Ian Kime
http://hottub.sythasite.com
SOURCE: how do you wear the
Adjust the wide panels over both your shoulders and lower back to ensure that you are comfortable and that your child is carried safely,then bring the thinner straps around just over your chest through the loops/rings and pull tight as if tightening a belt around your waist. be sure the straps are secure and it should hold tightly with no give.
