Did you unplug it from the wall. try unplugging if from the wall for two days and try it again.
SOURCE: My sony vega tv switches av settings
Will you specify Model number of Sony Wega TV to understand its circuitary.
SOURCE: Insignia TV - black and white
I would first try new cables, if not, then the board needs replacement.
SOURCE: Input Problem
Mine was the same, except i also could not access HD Components.
Unfortunately i had to get some one in, as the circuit board at the back of the tv was burnt out.You might have to get a technician in to service and replace the burnt circuit board.
SOURCE: magnavox mwstv66 black & white av
You probably have a bad input selection chip that is killing the coulor on those inputs.
do you have your tv set to the correct AV channel (for a scart connection) look at the Scart port on the TV (it should be numbered usually AV1..AV2..etc..)
Then you just need to switch to the appropriate AV channel on your TV
hope this helps.....
also check in your TV manual if the av socket you are connected to is an input or an output.
