Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor will not start, if I spin the blades it will run
THe motro does not start, but if I spin the blades it will run. Can you remove the motor to get at the guts of the motor. It appears to be a sealed unit
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Aug 10, 2009
Anonymous
Expert
Level 2:
Answers
51
Questions
Helped
21580
Points
113
If the motor starts when you spin it find the capictor and replace it
How to remove motor cover Black & Decker lawn mower EMAX32
Before you start removing covers and panels unplug the mower. Turn the mower over and carefully try to spin the blade by hand. Your checking to where the issue is most likely to be.
Does the motor sound different when you pull the Start trigger? If it sounds a lot faster than normal, it could be an issue between the motor and gearbox.
Does the blade spin really easily and feel like it's not bolted down? Does the blade not turn at all like it's 'locked' or 'jammed'?
- A loose or floppy blade is commonly the centre mount bolt for the blade is loose or the blade isn't seated correctly.
- A 'locked' blade could be a gearbox or a motor issue.
Cuisinart Mini prep plus: blade turns when there is no food to chop, but when there is, blade does not turn even though motor is running
SOLVED: Why won't my blades turn? - Oster Blend-N-Go My Blend - iFixit
https://www.ifixit.com/Answers/View/259808/Why+won't+my+blades+turn
Oct 1, 2015 - The blades may not be turning because the blade assembly is not fully ... Blades do not turn but the motor runs. ... this is a touch and go motor so it is easy to start the motor withoutproperly ... The blade should turn, if not they need to be replaced. ... My blender isn't even a year old and blades wouldn't turn. Why is my Magic Bullet just humming, but the blades ...
1 answer
Oct 29, 2015
Why are the blender blades not rotating? - Ninja NJ600
Apr 30, 2015
More results from www.ifixit.com
1helpful
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 • Blenders
1helpful
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
1helpful
My refrigerator has a burnt wire smell. The fans are running but the freezer doesn't seem as cold as it should be.
I'm guessing the condensor fan motor is not running. they smell like an electrical odor when they stop..remove back cover and see if something has gone into the blade area and stopped the motor from turning. if so, remove it ..if not, spin the blade and see if motor starts..if so, order new motor..you can use a floor fan to blow air towards compressor until you get a motor
Bruce
2answers
Can you tell me what is causing my delta mitre saw motor to run but the blade does not spin powerful enough to cut moulding?
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
2helpful
OUT SIDE FAN DOES NOT START WHEN A/C UNIT COMES ON. tHE FAN WILL START IF YOU GIVE THE BLADE A SPIN MANUALLY.
Be careful.....! If it starts when you push it you can hurt yourself seriously from the spinning blade. Sounds like your motor has a bad capaictor. Turn off the power (circiut breaker). Remove the old capaictor. Find the rating on the side. Replace it with the same rated size. If the motor has been subjected to running without a good capacitor for a while you "might" also need to replace the motor.
Good luck........
2helpful
2answers
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
1helpful
My Aeg dishwasher keeps coming up witha C2 fault code
The pump out motor in line with the outlet pipe could be faulty. Remove the moto and connect it to the mains for a few seconds. The motor should spin and the impeler inside the motor should spin freely. If the motor is faulty it would not work and must be replaced
Top Saniflo Home Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
