Question about Photography
My pandigital is not recognized by my windows 10 PC. I need to retrieve pics from the internal memory.
IT IS AN OLDER VERSION OF PANDIGITAL 7 INCH PHOTO FRAME
  • Photography Master
  • 6,080 Answers
Probably find there is no Win10 driver for it.
Posted on Jun 20, 2019
SOURCE:
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
SOURCE: my pandigital 1.8 inch digital photo frame won't turn on
You have to leave it in your US-B overnight to charge.
There is nothing in the instructions to explain this.
Posted on Jan 06, 2009
robmcd27
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
SOURCE: Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Posted on Dec 28, 2009
SOURCE: Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Posted on Apr 27, 2010
Tip
Pandigital digital Picture frame PC Recognizing Tip
Hi I just got this frame for Xmas ,,, I tried it my 1st Time it worked perfectly ... I then had other pics I wanted to have on my new frame ,,, Unfortunately I had no success getting the pc to recognize the frame ,, after a quick internet search I found out that I wasn't the only one this was happening to ...
Long story short ,, I figured it out ,, just make sure the power supply is plugged in when you are connecting the frame to a pc via usb ..
Thanks hope this helped .
BORNINDAFIRE
on Dec 28, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
What version of Windows is required to run Pandigial 7
the PANDIGITAL Pandigital 7" Digital Photo Frame is not computer dependent. you simply put the images you want onto a memory card and put the memory card into the frame. in other words, you can use it with any version of windows, mac, or Linux.
Jan 15, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Trying to upload 700 pics on my pandigital pic frame and I get an error that says something about volumes. I've deleted as many pics as possible but the frame should hold up to 6400 pics. What's the...
The internal memory of these devices is 512 mb, but if you add a memory stick, card, etc., you should have the memory to handle it. Not having experience with one of these devices, I'm guessing the internal memory is filling up. Hope this helps...
Jun 07, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Do I need software to get my comp to recognize a new Mad Dog Multimedia external DVD/burner drive?
Hello
Depending on which version of windows you are using, you might need to install the drivers for the device.
I know XP and older versions have a mush smaller internal driver database than windows vista or windows 7.
You don't necessarily need to install software to operate the device, just need the driver installed, then your computer will recognize the device.
Hope this can help you.
Kind regards
Andrea
Nov 15, 2009 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
I need instructions on how to load pics to my Optimus 07A08 digital frame.
On the back of the frame remove the memory card, then You need to use a pc with a Memory card reader, you can get usb card readers that simply plug in your usb, then copy all the pictures you want on the card from pc.
Oct 29, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Photography Logo
63 people viewed this question
Top Photography Experts
Steve Allison
Steve Allison
Ekse
Are you a Photography Expert? Answer questions, earn points and help others
