Hi All I am using 3250 from last one year The problem is that when i switch it on,white screen is displayed for a long time after that no action is taking place Please help me out, i have lot of data in my phone Thanks Anmol
To turn on the TV: Turning the Display On and Off There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but allows the remote to continue working. To turn the display on: 1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display. 2. Press the POWER button.
To turn the display off: 1. Press the POWER button. 2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please
make sure you rate my answer 4 thumbs up! Thanks so much for
understanding, it would be a huge help to me. I would be forever
grateful if you could do this for me. If you still have a question or
concern about this problem please just respond / reply to my answer here
before rating my answer.
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
Press action button to enter MENU.
Navigate to SETUP.
Scroll down to CONVERGE.
Press VOL > to select.
Press CH buttons to navigate up or down.
Choose CONVERGENCE ADJ or RESET TO DEFAULT.
If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left center of cabinet.
Press ACTION button to display red center correction screen.
Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION Remote Control must be in TV mode.
Press ACTION button to display red correction screen.
Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
Use the navigation buttons to align the RED cross with the white cross pattern.
Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
To exit press ACTION button repeatedly, then press CH up.
I use to have this problem the second time I restarted my Action Replay, so I reset it one more time and it worked. To restart an Action Replay by pressing L+R+A+B+Select+Start while the screen turns white after waiting a while after turning on your Nintendo DS.
next time there are many option beside strat windos normally, first try last known good configuration that worked, if didn't work try saFE MODE AND MAKE SYSTEM RESTORE. GO START>PROGRAM>ACCECORIES>SYSTEM TOOLS SYSTEM RESTORE. you can read about system restore here.
another option is repair windows(you need someone who know to do this or may be try to google it) or last option format it.
Mostly the blank lcd on 3250 dont need to change lcd.but the problem usually from emif IC(IC display).if you have an experience in phone hardware try to change it.But if you don't,take to service center because change IC display more cheaper than change lcd. so chek it up first.
According to your all information its problem with your display please repair your display or if your phone in warranty then rush to nokia service center and take a new display for it
