Question about Google Computers & Internet
My tablet froze on the copy your google accts apps etc from your other device
I did a hard reset, got to this screen and it wont click next
SOURCE:
SOURCE: I was downloading an update to my color id app and
I had the same problem and went searching online for a solution. You need to start your blackberry on safe mode and uninstall the application.
To boot up your BlackBerry Tour in Safe Mode, perform the following steps:
1. Take the battery out of the device.
2. Place the battery back in the device.
3. While restarting, press and hold the Escape key (the one with the arrow).
4. A screen will appear telling you that you are in Safe Mode. Select OK and troubleshoot the issue.
There are different versions of how long you have to hold the Escape key while the phone is restarting, so I just held it through the whole boot up time. It took a few minutes, but it's worth it.
Posted on Nov 03, 2010
Testimonial: "Thanks! It worked."
Zivan
  • 3 Answers
SOURCE: I have a Neopad Android 7" tablet Model no 8650
I googled the same and found that you have to upgrade your firmware.
It's a bit fiddly, but it does get the job done. You'll need an SD card
to transfer the data. The link is: http://www.mediafire.com/?ncqvw4bpc0s6e
Load the instructions first then proceed. All the best...
Posted on Nov 16, 2011
  • 6 Answers
SOURCE: Frozen Galaxy Tablet
Update your firmware by using your sd card... place sd card in compurter...Go to galaxy website download firmware to your sd card then follow direction from website how to start the download on your galaxy.Good luck
Posted on Dec 17, 2011
  • 86 Answers
SOURCE: google play wont dowload my apps
Better to reset your tab once...
Posted on Dec 24, 2013
jeeperscr29876
  • 87 Answers
SOURCE: My dragon touch won't update or install apps. ..it says it can't receive info from server. I've reset the tablet and cleared the Google data catches and deleted and reinstalled my Google.still no work
It won't update if it's stolen, you are blocked from server, google is really Good on that. If not Make sure you sigh in to your account first and make sure device is properly signed in. it becomes a problem when you are using multiple devices so double check your account. Also check settings Who is signed in on your pad and what account you are on, and where else you have being using it, check promisions on your pad and account. Make sure your devise is capable for an update. Good luck
Posted on Jul 07, 2015
What do I do to my next book Ares 8 ? Every app I open says not responding?
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet. how do you rest nextbook tablet
Jan 07, 2018 | Tablets & eReaders
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Mar 07, 2015 | Tablets & eReaders
How do I unfreeze the computer
In case your Android smartphone is complete frozen and not responding to you at all, the above restart method won't work for you! To unfreeze Android smartphone that is dead froze, force restart it by holding the Sleep / Power key and the Volume Down key simultaneously until your device's screen goes blank.
This force restart key combo varies from device to device, so it is advised to check your device manual for the right combo. If your Android device has a removable battery, you can remove it and put it again and it will restart the device.
Jan 19, 2015 | Tablets & eReaders
My hipstreet flare won't install or allow me any google playstore apps...
That's because the Hipstreet Flare tablet does not support the Google Play Store. Several of the cheaper tablets, and many of the proprietary ones (such as Amazon Kindle Fire) don't. You can manually download the APK files, upload them to the tablet, and install them that way, but you can't actually install apps directly from the store to the tablet.
Mar 25, 2014 | Cameras
Tablet froze in the middle of restarting and the screen wont respond
Wait till the device runs out of battery (or pull out the battery) then try to reboot.
Nov 30, 2013 | Samsung Galaxy Tab 2 7.0
Google play stop working on my irulu pad, it just says no connection
you have to reset the tablet to factory conditions. i was at my wits end before i did this. o stay away from opera, firefox, and chrome there are other browsers
Nov 14, 2012 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Open Questions:
Computers & Internet Logo
16 people viewed this question
Top Google Computers & Internet Experts
Peter Dragonetti
Colin Stickland
Colin Stickland
George Etukudo
George Etukudo
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
