Question about Homelite Garden
What is the fuel mixture for a homelite 30cc engine on a small tiller/cultivator
  • 45 Answers
The oil ratio is not adjusted to the engine it is the formulation of the oil. You mix your oil the way the bottle states. I have been working on 2 cycle engines since the 70's at a motorcycle, ATV and lawn & garden dealership. If you have doubts about a 50:1 oil do like I do and put 8/10ths of a gallon of gas in you jug and use a bottle of oil for a gallon and mix.
Posted on Jul 01, 2019
SOURCE:
  • 3 Answers
SOURCE: Mantis Tiller: twocycle engine,mixture oil/gas for
40 to 1
Posted on Dec 02, 2009
  • 277 Answers
SOURCE: fuel oil mixture ratio
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Posted on Jun 23, 2010
2strokeguy
  • 183 Answers
SOURCE: I was looking for the
From the factory, when everything was new, the Hi and Lo screws were 1 1/4 turns out. As things wear and as fuel forms deposits in the carb, you may have to adjust the screws out further. Usually Lo gets stopped up a little first. Lo side adjustment effects how the engine goes from idle to upper speeds. Hi side only effects the engine at wide open throttle. If you have to go more than 2 1/2 turns out on either screw, then a carb overhaul or replacement is in order.
Posted on Sep 12, 2010
  • 130 Answers
SOURCE: i have a homelite 30cc blower that is roughly 6
You are safe running a 40:1 ratio. 8oz. of oil to 2.5 gallons of fuel.
Posted on Feb 12, 2011
wentlanv
  • 710 Answers
SOURCE: fuel lines became brittle and
You didn't give me your model number, so I will direct you to a website where you can see a diagram: http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Tiller-Parts?Type=Gas
Just click on your model number and a schematic and parts list will pop up.
Hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Posted on Apr 13, 2011
Trouble shooting briggs small engine carburators
TIME FOR A CLEANING AND REBUILD. CK FLOAT ADJUSTMENT AND FUEL LINE FOR CRACKS.
Sep 07, 2014 | Garden
Fuel to oil ration for homelite htc12
good question . most modern 2 cycles run either 40 to 1 or 50 to 1 ratios.fuel air mixtures must stay on the rich side of the power band to allow a small amount of un burned fuel to flow past the exhaust vaves and provide a cooling effect.A too rich oil gas ratio is harder on the ignition coil and might pound it out. however a too lean , not enough oil situation will scoure the cilinder walls result in sticking rings bearing faluire ect. so i would go with 40 to 1
Aug 24, 2014 | Garden
Why Tiller cranks but will not run when you need it to till?
If you don't have a manual, could can read/download it at this link.
If the engine stalls under load, the mixture may be too lean. There should be a mixture screw on the carburetor. Note its position, and turn it counter-clockwise 1/8 of a turn to see if there is any improvement in engine performance. Repeat this but don't exceed about a half turn.
The tank has a vent and this should be kept vertical under the cylinder cover in the small "pocket" in the cylinder cover.
Lack of power can be caused by a dirty air filter or blocked muffler screen.
See the article below for troubleshooting 2-cycle engines
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 30, 2014 | Mantis 2-Cycle Tiller
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Feb 17, 2012 | Ryobi Garden
Forgot to drain the gas last fall and found it had small amount of water in the tank. Drained it out and cleaned the fuel filter, cleaned the carb out and now it starts, but runs only if the choke is on.
I would recommend replacing the fuel filter and spark plug. If this is a 2-cycle engine be sure you are using fresh gas with the proper oil mixture. If your engine has a fuel primer bulb be sure to push it several times until you feel resistance before starting and make sure there are no fuel leaks. Failing that you may need to adjust the carb fuel mixture screws after the engine runs long enough to warm up (1-2 minutes). Check your owners manual for other troubleshooting procedures. Good luck.
May 24, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Have this rototiller without a manual and need to know about fuel
the mixture is usually on the machine somewhere--if not go the honda website and look up info for that model
May 08, 2010 | Honda 25cc 4-cycle Mini Tiller
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine will start but won't stay running i have replaced fuel lines but don't know if i have them hooked up correctly
The top of the carburetor is where the fuel line with filter out of the tank goes. The other line on the bottom of the carburetor is the return line it goes back into the tank. Of course your fuel mixture may be old. Anything over 30 days now is being considered bad fuel. You may need to mix up some fresh fuel mixture and try it.
Good day.
Oct 15, 2009 | Mantis 2-Cycle Tiller
Garden Logo
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
lnbn1975
Are you a Homelite Garden Expert? Answer questions, earn points and help others
