Question about Epson Office Equipment & Supplies
Epson 4540 Errors - Epson Office Equipment & Supplies
The 4540 will not print after it says an ink cartridge is empty. How can I make the printer print more pages without changing the cartridge?
probably cannot do this as printing with out ink can damage the printer head if the cartridge is empty , it is empty so replace the cartridge and reset it
Jun 11, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
Communication error message occurred during transmission. upper cornr has error code b52
This sounds like a fax error, such as the phone line dropped, the remote system hung up. or something like that.
May 19, 2015 | Epson WorkForce Pro WP-4540 Color Ink-jet
Wp 4540 leaking ink
Possibly leaking from the collection tank in the bottom of the printer, they can only take so much then leak, you can try to remove it and empty it if you can get to it.
Or you may be wiser to try and soak it up with kitchen paper towel, you will need a fair bit to soak it up!
Jan 16, 2014 | Epson Office Equipment & Supplies
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
Yellow leak problem, Any solution?
Unfortunately this is a known issue with these printers and caused by faulty printer manufacture.
You can see what I mean if you do a search on Youtube to find videos like this:
http://www.youtube.com/watch?v=OIVNTMt0ua8
The only solution is to contact Epson and get a replacement, assuming they'll honour their responsibility.
Nov 12, 2013 | Epson WorkForce Pro WP-4540 Color Ink-jet
Error E000 on Canon copier NP-4540
check the light maybe short. if it is not check the thermostat
Jun 24, 2009 | Canon Office Equipment & Supplies
Open Questions:
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
