Question about Sewing Machines
How do i drop feed on the xl2600i to do free motion
SOURCE:
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
SewExpress
  • 41 Answers
SOURCE: fREE MOTION QUILTING
Hi Susan,
You're absolutely correct, you'll need to either drop the feed dogs (lever generally located near the bobbin case or on the outside base of machine) or cover the feed dogs with a plate (many machines have this included).
Then... you'll need to lower the presser foot - when you lower it, it should NOT touch the bed of the machine but sit slightly raised off the fabric surface. As you stitch the presser foot will lower onto the fabric to hold it taught as the needle penetrates.
Oddly enough it's easier to achieve smooth stitches when sewing at a faster speed, but begin by stitching fairly slowly until you get a feel for free-motion stitching. You'll be doing all the guiding and it may feel a bit strange and uncontrolled at first.
Position yourself at your machine so that when your hands on your fabric/bed of machine, your shoulders are relaxed (not all hunched up) and your elbows are slightly higher than the bed of the machine.
You'll want to stitch in a side-to-side or back and forth motion (as opposed to trying to turn the fabric.
Best of luck with this technique. Once you're comfortable with it, you're sure to enjoy the freedom of creating!
Happy sewing,
Kim & Linnette
Posted on Jul 31, 2008
SOURCE: Drop feed
I found the drop dog feed lever. Problem solved.
Posted on Sep 28, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
RichSew
  • 220 Answers
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
Posted on Jun 03, 2010
How do I set the Husqvarna 300 sewing machine to do free motion embroidery. Do I need the embroidery attachment and get the machine to embroider with or with out the card
You can do embroidery or you can do free motion. If you're quilting a quilt sandwich (fabric, batting, backing fabric), you probably want to do free motion quilting. Embroidery would work better on fabric (with a stabilizer) but without the batting and backing fabric.
For free motion, you want a free motion foot--your machine's manufacturer probably provided one in the accessory kit (called a darning foot) or there are many generic free motion feet available for purchase (ie Big Foot quilting foot...). The BIG difference with a darning foot or free motion foot is that the shank is shorter than other presser feet because there needs to extra space between the presser foot and the needle plate so the quilter can easily manipulate the fabric. Usually, free motion quilters will drop the feed dogs to avoid feed dog interference with the fabric's movement, however, some quilters don't drop the feed dogs--just whatever works best for you and your machine. In addition, I use a Supreme Slider on the sewing machine surface--a silicone mat that provides a slick surface to help the fabric move.
There are a lot of web sites and video tutorials on free motion quilting. Take some time to watch them and then practice, practice, practice! It's an acquired skill so the more you practice, the better you will be.
Feb 09, 2018 | Husqvarna Sewing Machines
How do I free motion on my excel 18w
Free motion is similar on most machines.
Install a brand new sharp needle (embroidery, top stitch, microtex, or universal) of the size that is compatible with the thread weight and fabric.
Drop the feed dogs. If you machine doesn't have the capability, there should be a feed dog cover in your accessory kit that needs to be covered,. This prevents the feed dogs from interfering with your manual maneuvering of the fabric.
Install a darning foot or free motion foot.
Test your stitch and adjust the tension so the threads meet in the middle of the fabric.
Then, it is a matter of practice, practice, practice...
Learn How to Free Motion Quilt Stippling
Free Motion Quilting Tutorial for Beginners Suzy Quilts
https://wpt.org/SewingWithNancy/Video/free-motion-quilting-beginners-part-1
How to Free Motion Quilt on Regular Sewing Machine
lots more web sites available...
Jan 03, 2018 | Sewing Machines
Can I do stippling on my 400xl
This is free motion quilting. There are a ton of web sites and videos available. You'll need a darning or free motion quilting foot for your machine. Drop the feed dogs. If you are certain you want to do free motion quilting, a Supreme Slider helps you move the fabric.
https://www.amazon.com/Supreme-Slider-Motion-Machine-Quilting/dp/B007XGITA2
Free Motion Quilting for Beginners 10 Tips
Free Motion Quilting Beginner Tutorial 1 of 4
Mar 07, 2017 | Sewing Machines
Does the 4562 singer deluxe freearm electronic speed control 32 stitch function come with a freemotion foot and do the feeddogs drop?
Most machines include a "darning" foot, which is the equivalent of a free motion foot. However, there are multiple choices of free motion feet that can be purchased elsewhere which are made of various materials, in different shapes, and also with springs to create bounce--just something to consider, but not necessary.
Your machine should either have the ability to drop the feed dogs, or a cover plate that snaps over the feed dogs to prevent them from contacting the fabric when free motion quilting.
Your manual should have information as to what is included.
Instruction Manuals
Feb 18, 2017 | Singer Sewing Machines
Can I drop the feet
If there is no feed drop lever (on the free arm near the feed dogs, front or back) then you need to use a darning plate.
Oct 17, 2014 | Singer One Plus Computerized Sewing...
Why do the feed dogs reset while free motion quilting?
Your machine's feeddog drop control may loose or worn. Your authorized Viking repair dealer can fix the problem .
Jun 20, 2014 | Husqvarna Viking 1
May 29, 2010 | Juki TL-98Q
Drop feed
Sep 28, 2008 | Sewing Machines
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
