SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
SOURCE: I have a 2005 Cub Cadet Series 1000 LT 1050 with
Sounds like the drive belt has been thrown off of the drive pulley.
It is fairly simple to identify the drive belt. - it is the one that is connected directly to the pulley coming donw from the motor... and it travles over a tensioner pulley (that you control with the clutch) and then over the large pulley that is mounted over the transmission.
Check to be sure that the belt is ON the pulley... and not broken..
-Jim
SOURCE: I have a cub cadet lt 1050 mower and I need to
I just replaced mine today and let me tell you it was a pain in the ****, Had to remove the deck, steering attachment on the underside,and the electric PTO. Took about two hours.
SOURCE: i have a cub cadet lt 1050 need diagram for drive
Hi. All of these questions are answered in the owner manual. TO download one go to this link http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
J.
