Question about Haier HLP21E Top Load Washer
Error e1. washing machine will not drain. The tub is full and between the wash and rinse.
    Guru:
  • 1,738 Answers
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Posted on Aug 10, 2009
  • 975 Answers
2 things to look for , first check out the safety switch where the lid is , second it could be the DRAIN MOTOR PUMP , it could be clogged with lint & debri , need to take it out clean it and replace it back , its located at the bottom where the DRAIN HOSE is connected , good luck , AJ
  • rodel Aug 08, 2013
    I have also that problem. E1 error. can not drain. my haier washing machine is top loading. please help. thanks
SOURCE:
We have just purchased a Siemens WM10K20SZA. WE trying to fiure out which cycle uses the least amount of water as we have a terrible drought in the /western Cape.
set the water level for the wash load
in other words do not use full wash for a part load
next do not use deep rinse
really to save water only wash when there is a full load
save the water to the tub , not down the drain
use that for watering the garden
the second rinse water save to the tub and that is clean enough to use in the first wash next time as it is only rinse water
Oct 18, 2017 | Siemens Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
    many machine spin a full tub as they are pumping the water out
    this helps to even out the washing load and reduce the unbalance situation
    when the water is removed , the machine progresses the program to a high speed spin
    call a technician as there may be a problem in the program board
    Jun 11, 2016 | Kenmore Washing Machines
    Wash cycle stops before pumping out. On separate spin or rinse cycles it will not work at all.
    Washer machines have a pressure switch of some type and this pressure switch lets the control or timer know how much water is in tub. So if tub is full of water, look for a blockage in drain pump or in drain pump screen.
    May 12, 2016 | Washing Machines
    LG WM0642HW
    make sure it drains the water out..it will not go through spin if there still water inside the tub... also drain is timed. Is there any error message? thx
    Mar 01, 2014 | Washing Machines
    Stops before rinse cycle... won't drain or spin.
    The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
    on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
    FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
    lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
    Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
    GE Nautilus won't drain after Rinse Cycle
    Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
    Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
    Haier HLP21E Top Load Washer Logo
    6,484 people viewed this question
    Top Haier Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    jimorris77
    Marvin
    Marvin
    Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
