Question about Generac Electrical Supplies
I have an 11kw Generac with a fuse problem alarm. The fuse is good and it won't let me clear the alarm.
    Sergeant:
  • 225 Answers
What is the alarm display? And what is your generator brand? If possible to say detail it will be better.
Here is diesel generator website:
https://starlightgenerator.en.made-in-china.com/
Posted on Aug 23, 2019
3 Suggested Answers
SOURCE:
  • 24 Answers
SOURCE: What is wrong when my 11kw generac generator starts for about 3 seconds then shuts off and shows the low voltage light.
There are two reasons that we see this shut down code appear.. especially during extreme cold weather conditions. The two reasons are worn or broken slip ring brushes or frost build up on the slip rings. Both cases prevent the generating portion of the generator from transferring voltage. If this occurs only during cold weather, I would switch the generator to off and press 'enter' (this will clear the shutdown code) then switch the generator to manual and attempt to start (may have to clear code once or twice more). If the generator starts and runs without shutdown then you can switch back to off and then to auto. If it starts and runs ok then this signifies that the slip rings were frosted over and once cleared will run normally. If the unit continues to shut down on undervolatge, a generac tech will have to be contacted to test the brush resistance and possibly replace. If the issue is slip rings frosting over during cold weather producing undervoltage issues, I would recommend a Generac cold weather kit (part#6212) to assist in preventing this issue from reoccurring. the cold weather kit consist of a battery pad heater and a heated oil filter wrap to maintain temperature in the crankcase.
Posted on Mar 02, 2015
emissionwiz
  • 85178 Answers
SOURCE: How many quarts of oil do i need for my 11kw generac #7033 generator
1.1 US Quarts
Posted on Mar 30, 2018
I was running my 11k gen in the manuel position cold weather when doing this I reved the engine up and it stopped on over speed how do I reset the alarm
not sure what unit you have or if electric start...but elce start then disconnect the battery for 10 minutes and re-connect. Clears the code on generac and some other manufacturers.
former generac rep.
Hope this helps.
Jan 01, 2018 | Cars & Trucks
11kw generac gen just installed I need to adjust the utility loss time greater than the 10 seconds factory setting what is the dealer password? I believe I have the evolution control panel
if you installed it yourself the place you got it from should tell you that information. most dealers who do installs will not tell you.
Oct 10, 2017 | The Computers & Internet
Error code - 2400...stopped-alarm- fuse problem, fuses checks good
I has this problem after performing Schedule A maintenance. Called Generac. They advise this a trip caused by removing the fuse before work to prevent engine start up, The fix is to turn unit in off position and then press ENTER key.
Mar 14, 2015 | Generac 20 Kw Air-Cooled Standby Generator
A class won't go
All fuses good? If all fuses good take the battery cable off and let it reboot for about 15 minutes than hook it
Feb 28, 2013 | Mercedes-Benz Mercedes Benz A Class Maisto...
I have a Generac Guardian 20kw air cooled standby generator. I recently replaced the battery charger as the battery went dead a few times over the last several months. Upon replacing the charger, I now...
The battery could be bad. Try to measure the battery voltage when you try to start. If the battery is bad then the voltage will drop quite low when the battery is loaded with trying to start the set. If you can borrow a similar battery you could just try with it.
Oct 21, 2017 | Generac Guardian Model 5784 20 Kw...
I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
Oct 03, 2009 | Generac Electrical Supplies
Electrical Supplies Logo
48 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
