SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
SOURCE: trimmer line on spool of Challenge 250 Watt Grass
I did a lot of searching for a manual but I guess Argos does not want their customers to know how to use their product. When you are use the trimmer, most rotate clockwise. You may find on the spool an arrow showing direction to wind line. Otherwise you will have to take it apart the trimmer and remember with direction the spool turns. Wind the string on the same direction turns. plus try a little wd40 on the line to keep it from sticking together.
Cheers.
SOURCE: Yardworks cordless grass Trimmer /
To remove old spool just unscrew the center screw on the blade. Push out with force and put new one in place, afterwards screw back.
Thanks,
