I like to add some memory to my smart TV with an external device go into USB and activate on input or source
SOURCE: Playing movies from external hard drive
As both Western Digital and Iomega have not made much news about these two devices, I had not realized they existed. They would be the best solution for you. Just make sure you convert the video into the correct format.
SOURCE: "unable to format external memory" 4gb microSD 4gb insignia
Because It can't support higher than 2 gb SD micro card...
SOURCE: How can I set up my Samsung SSD 256 GB hard drives
First of all, does the Motherboard support RAID? If so, you may need to get into the RAID BIOS and set it up. Make sure there's no critical data on the drive(s) you are mirroring or striping! Some systems have a GUI RAID utility as well for setting up the drive(s). Depending on the size of the drive(s) you're using it can take a while for the setup to complete.
SOURCE: I have a clavinova CVP
If you go to Yamaha website,CVP 409 specs, it will tell you how to hook up each one of the interfaces (ie floppy, usb, external hd and mem stick) and this should apply to other models.
SOURCE: maxell max data 1tb hard drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working
ports (com&lpt) right click update driver
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
