Question about Bosch Dishwashers
Bosch diswasher tapping noise
Continuous tapping from bottom of dishwasher
SOURCE:
  • 2985 Answers
SOURCE: Bosch diswasher
If it is new- then the fishy smell is almost certainly the motor and circuit boards 'cooking' in- most motorized electrical devices have an initial pong. However if it persists after say 10/15 cycles begin to suspect an incipient fault.
Posted on May 14, 2007
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
SOURCE: Bosch dishwasher
I had this same problem and in addition as it ran water dripped out the bottom while the dishwasher was running just before the tap light came out. Check the outlet hose is not blocked. Ours was blocked at the T junction where it met the sink outlet. Once the blockage was cleared we hit another problem - the pump kept trying to drain - even when the door was open. Found an excellent solution to that on this site. It had occured as the previous problem had casued the flood switch to be triggered. We had to tile the sihwasher back 45 degrees to fix it. Now its workig fine again.
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: Diswasher Pump won't stop running
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills, OK, then this ISN'T a solution to your problem.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
SOURCE: my bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Posted on Nov 14, 2009
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Have BOSCH diswasher model SHE44C06UC/22 and it continues to cycle but never drys
That could either be a problem with the control module or the heating element...my first guess would be the heating element... as it is looking to sense it working and does not...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 29, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Hello,what tool do you need to remove the screws in the bottom of my bosch diswasher,they seem a odd shape.
Hello Steve, The screw heads should be a "Torx" size T20. Hope that answer's your question. Good luck. Macmarkus :)
Jun 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Bosch diswasher SGS5942 does not heat up
this is a common problem with dishwashers.the thermostats are faulty and be replaced by someone who knows what they are doing.
Oct 24, 2009 | Dishwashers
DISHWASHER DRAINING POORLY
Check to see if you have a plugged, kinked, drain hose or screen. Do you know how to disassemble the bottom of the diswasher to get access to the drain hose? Also, is the dishwasher drain and hose properly vented?
Aug 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
almost certainly your element is faulty. waret does not heat up allowing timer to proceed
Mar 22, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
42 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
