I have a paper jam and the paper got stuck where i cant see it
what do i do? take it a part?
Fixed the problem by running two sheets of heavy card stock
through at the same time.
With the machine off, positioned the two
sheets in the feeder so that they would be pulled in when the printer
was turned on. When turned on the printer, it drew the two sheets
through and this reset the paper sensor. Previously found
that only one sheet at a time did't work.
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
