Question about The Health & Beauty
Have a Celebrity X , 3 Wheeler, hardly used, brand new batteries, but the power guage only goes to 1st green light? yet it goes 16 to 18 miles on charge, why on full charge doesnt it goes all green bars on guage. Charger shows full green charge?
SOURCE:
  • 3940 Answers
SOURCE: old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
Posted on May 03, 2009
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
hawk127311
  • 350 Answers
SOURCE: dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Posted on Nov 06, 2009
  • 165 Answers
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Posted on Feb 27, 2010
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Why wont my celebrity x take a charge brand new batteries brand new charger
Is the charging circuit fuse blown? There are two hidden under the floor mat and hatch. Pride say that they don't exist, but there they are and one of mine mine was blown by a faulty XLR lead
Apr 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
Celebrity x scooter wont charge
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File + Print for future,hope this has helped,Colin.
Nov 22, 2011 | Health & Beauty
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Battery light & brake light flashes on & off. went to parts store & had battry & charging system checked. was told battery was bad , bought new one .problem still there not as bad...
You need to get a volt meter on it. Your battery should be around high 12 to 13 volts while not running, and increase a little without going over 14 1/2 volts running.
Aug 11, 2010 | 2007 Nissan Titan LE
Health & Beauty Logo
Top The Health & Beauty Experts
D. E. Hev
poizniv
poizniv
Level 1 Expert
OHare
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
