SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
SOURCE: Can't find temporary recovery log
the only solution i can find to your problem is to delete the firmware update you've put on your table,you need to wipe the data,just reset it to factory settings,,just hold the back and power key then if you see it light ang the logo just release the power key the back remain,then your on the system mode just select wipe data fastory reset or what ever you want just press up and down volume to select..then press back button to start.....hope it help....
SOURCE: I want to hard reset
how to hard rest Samsung Galaxy Tab Tablet PC
press and hold -sound and power for 5 second you well open recovre mod press hard reset and press the long words and write yes the phone well restart and well pe in factore mod
SOURCE: How to fix hard bricked Hyundai Hold X700 NoBluetooth tab?
you can format your OS and need to delete all application you use on your tab,you can format by go to your nearest hyundai show room
