It is not you tv its the plug on theb wall. It is probably loose, and causing the intermittent problem you are having. You may notice looseness as you plug it into the wall. Your TV is fine.
A poor connection will always give you intermittent problem. It don't matter about how often it work. If it is the power cable you can get a new one from any electronic parts store. It is best to get an original replacement, but you can also replace it with a similar kind, and make sure that you replace it with either same size or bigger.
i dont notice any looseness no, but i agree the plug/wire seems to be causing the problem, where can i get another? still how does it explain how it turns on every few days
thanks.
thanks.
tried the power lead off PC still same thing flashy light then no power.
il have to send it to someone its ou of gurantee just aswell bummer
