Does anyone know how to convert an ACDSEE (FotoAngelo) FAP or EXE file into an AVI or anything that is not an EXE file? Thanks, Rod
  • Computers & ... Master
  • 4,983 Answers
Omg that is old, I used to use that with windows 95
what memory that is. wow.
forget EXE ok>
fork FAP but is now a banned word, so searching FAP takes you to Pr0N sites
I google for you, is your google broken?
https://www.coolutils.com/online/FAP-to-MP4
1st hit after avoiding all to Pr0N sites
the new ACDSEE does not even mention FAP
so what versios of ACDSEE do you have.
1995 to 2019 LOTS.
exe is binary executable file, and is NOT VIDEO Ok
and see no hits on video.fap , zero
so where did you find these files.
my guess is you are very confused about video files.
there are vast applications that can coverert any video to MP4. did you try that first.
google free video converters.
here is what FAP means (clean)
FAP file is an ACD FotoAngelo Project. ACD FotoAngelo is a program for creating screen savers and slide show presentations from your images.
so is not a video file at all
it is PROJECT file only.
ref1"
https://www.filedesc.com/en/file/fap
Posted on Jun 19, 2019
SOURCE:
Noggin
  • 944 Answers
SOURCE: AVI file is not running
With .avi files the issue is usually which video codec has been used to encode it - all players will have certain codecs installed, and if the second player you describe does not have the approprtiate codec then it will struggle to play the file - occasionally the audio codecs can have the same effect, also on video. In your video conversion program you should be able to choose from a list of codecs to use to encode the .avi file, check which one you used and then check it is installed on the computer that is experiencing the problem. Windows media player, if it is fully updated should be able to cope with the majority of codecs, the best player for .avi files at the moment is DivX player, available free for download at; http://www.divx.com divx player also may need to be fully updated after you install it, this is an easy procedure, just click "Check for new versions" in the "help" menu to make sure you have the latest divx codecs installed Hopefully this will allow you to play the files on both machines. If you still have trouble, then type the name of the codec used by your converter program into a search engine, and you should find a location to download it from with installation instructions. Hope this helps, ask again if you still have trouble :)
Posted on Apr 21, 2007
  • 57 Answers
SOURCE: Converter
Download the Amipro to Word converter from here:
http://www.gmayor.com/downloads.htm
Unzip it and install the file ami332.csv in the folder \Program
Files\Common Files\Microsoft Shared\TextConv
You'll be able to see your amipro files when you try to open a file in
Word. You'll get a warning message thast you're opening a non-word
file, but then it opens up just fine.
Rate if this helpful to you.. Thnx!
Mon =)
Posted on Nov 12, 2007
SOURCE: Converting files
You must click "Add", then you click the button behind "Source File" in this dialog you search your film and then click "Open" pic1.jpga331ac4.jpg
then click the button behind "Target File Path" and then you can
then you can add other films on the same way how i explained you. When you have all films, which you want convert you click "Close"e4649d5.jpg
Then convert the converter your films.
With the button "Stop" you can stop converting,
with the butten "Del" you can delete the film, which you not any more want convert. With "Close" you can close the Programm.
Posted on Jun 22, 2008
SOURCE: I want to convert an avi extension video file to wmv
I had to convert the video to WMV first using Smart Soft Video Converter but there are many other converters that will do it. Then convert the WMV to SMV using the Phillips SA30XX Media converter program supplied on the CD that came with the unit. If you don't have the CD with the software you can download from http://www.p4c.philips.com/files/s/sa3020_37/sa3020_37_mcs_aen.zip .
Posted on Dec 03, 2008
SOURCE: Pandigital 7" photo frame won't play avi files
I made my pandigital 8" touch screen videos work by:
used MOVAVI software to convert my .mov video to avi
then had a polarid mp3 player which had a simple software to convert to the polarid mp3's video files. large's video selection was 320x240.
that worked.
RA
Posted on Dec 28, 2010
Films on usb have no sound
suggest downloading as many Android media players onto the TV from Google playstore and try them all. There will be some AVI files that just don't play on Android you might be able to convert avi to another video format with a file converter program.
Suggest VLC player but it is troublesome on android operating systems.
might work on your laptop or computer for the avi file.
Nov 26, 2017 | Televison & Video
Tip
Questions and Answers about MOV Conversion
<a></a> <a></a><span><span><span><span><span><span><br /></span></span></span></span></span></span> <span><span><span><span><span><span>Question 1: My digital camera can record videos in MOV format. I want to convert them into AVI format so that I can play them on Windows Media Player. There are many converters on the market available, but can anyone recommend me the best one?<br /></span></span></span></span></span></span> <span><span><span><span><span><span>Answer 1: To convert MOV to AVI format, Wondershare Video ConverterPlatinum is just what you need. If you want to play MOV movies with WindowsMedia Player or enjoy the music from the MOV videos, you should never miss thisMOV to AVI Converter. It is absolutely the best Video Converter for you to </span></span></span></span></span></span><a href="http://www.macvideoconverter.org/mov/convert-mov-to-avi.html"><span><span><span><span><span><span>convert mov to avi</span></span></span></span></span></span></a><span><span><span><span><span><span> and many other formats. This software has an user-friendlyinterface that you can handle it easily!</span></span></span></span></span></span> <span><span><span></span></span></span> <br /> <span><span><span><span><span><br /></span></span></span></span></span> <span><span><span><span><span>Question 2:Converting a QuickTime MOV file to MP3? I am wondering if there is any way totake the audio out of a QuickTime MOV file and just save the audio as a MP3file. Is there any way that I could do it? Thank you.</span></span></span></span></span> <span><span><span><span><span>Answer 2:Wondershare Video Converter Platinum, a free downloadable MOV to MP3 Converter,would be the best solution for you to convert MOV to MP3. It can help you toextract audio from QuickTime MOV files and save as MP3, AAC, AC3, WMA, etc.</span></span></span></span></span> <span><span><span></span></span></span> <span><span><span><span><span>Question 3: Doesanyone know any converter that can convert QuickTime movie videos toMPEG?"</span></span></span></span></span> <span><span><span><span><span>Answer 3: Infact, this free downloadable Wondershare Video Converter Platinum is anall-in-one converting utility for converting almost all popular video formats.You can not only use it to </span></span></span></span></span><a href="http://www.macvideoconverter.org/mov/convert-mov-to-mpeg.html"><span><span><span><span><span>convert mov to mpeg</span></span></span></span></span></a><span><span><span><span><span> , but also convert WMV, FLV,MKV, RM, RMVB, etc to MPEG and also convert MPEG to AVI, ASF, WMV, MP4, etc.</span></span></span></span></span> <span><span><span></span></span></span> <br /> <span><span><span><span><span><br /></span></span></span></span></span> <span><span><span><span><a><span></a></span></span></span></span></span><span><span><span><span><span><span><span><br />Question 4: Convert MOV to WMV? Hello. Can anyone recommend or suggest a software tool for the PC (or an online service) that will convert QuickTime MOV files to WMV format? Thank you.<br />Answer 4:</span></span> Acting as a MOV to WMV converter, <a>WondershareVideo Converter Platinum</a> can easily convert MOV to WMV format to meet yourneeds. It is the top-rated MOV to WMV converter which enables you to </span></span></span></span></span><a href="http://www.macvideoconverter.org/mov/convert-mov-to-wmv.html"><span><span><span><span><span>convert mov to wmv</span></span></span></span></span></a><span><span><span><span><span> format with the least qualityloss. So with the assistance of this converting tool, you can enjoy QuickTimeMOV files on Windows Movie Player easily.</span></span></span></span></span> <span><span><span></span></span></span> <br /> <span><span><span><span><span><br /></span></span></span></span></span> <span><span><span><span><span>Question 5:Anyone have professional video conversion software to convert mov to othervideo formats, such as flv, rmvb, mp4, swf, asf, vob, xvid, 3gp, mkv, wav, etc? thanks for help.</span></span></span></span></span> <span><span><span><span><span>Answer 5, WondershareVideo Converter Platinum is just what you need, it is such a powerful softwareto make video conversion among different video formats and convert videos todifferent cool devices, such as ipad, iphone, psp, ipod, mobile phone, zune,etc. </span></span></span></span></span>
on Jun 13, 2011 | Computers & Internet
Tip
How to convert AVI to MP4
Audio Video Interleaved is the full form of AVI that is a computer graphics animation format. It is used in Microsoft Video for Windows and it interleaves synchronized audio and digitized video frames into one single file. You can play the clips generated in AVI format in a Windows PC that is independent of the screen resolution and palette.<br /> The Moving Pictures Experts Group defined MPEG-4. This format helps deliver high quality audio and video streams for cell phones and broadband connections. The MP4 format also supports 3D objects, texts, and different media files. MP4 (short form for MPEG-4) is a container format that helps one combine different streams of multimedia into one file that is streamable and supports all kinds of multimedia data. Many people are looking for some ways that will help them in converting AVI to MP4. If you are on this page, it is obvious that you too, want to know more on how to convert AVI to MP4.<br /> The following I wil show you step by step to convert AVI to MP4.<br /> Step 1: Free download <a href="http://www.mediaconverter.biz/guide/convert-avi-to-mp4.html">convert AVI to MP4</a> software, install and run it.<br /> Step 2: Click "Add". Add the files you would like to convert to MP4 format.<br /> Tips: This converter can not only convert AVI to MP4, but also convert M4P to MP3, convert M4V to MP4, convert WMA to MP3 etc.<br /> Step 3: In the "Setting" button, choose MP4 format (*.mp4).Click the "Start" button to start converting AVI to MP4.<br /> Step 4: Click "OK", then finish it.<br /> Here is the list what you should take into consideration when you looking for a AVI to MP4 converter:<br /> 1. The software should be very user friendly and easily understandable.<br /> 2. The error handling should be perfect. I've seen a few AVI to MP4 converters displaying error message "No Error Occurred". You'd better stay away from such AVI to MP4 converters.<br /> 3. Customer support should be fast enough to respond in case of any problems<br /> 4. Speed while converting AVI files to MP4 should be good enough.<br /> 5. A trial version should be available for anyone who want to try the software.<br /> I recommend this <a href="http://www.mediaconverter.biz/">media converter</a> software is designed for you to convert AVI files to MP4 onto your ipad. Also this software support many formats: M4V, WMV, WMA, ASF, M4A, MOV, 3GP, 3G2, DVD VOB, h.264, HD(.m2ts; .tp; .trp; .ts), FLV, SWF, MPG, XVID, MP3, AC3, OGG, APE, AAC, WAV, MKV, MKA, etc. So, why not download one to have a try?<br /> More Related:<br /> <a href="http://www.mediaconverter.biz/guide/convert-avi-to-flv.html">How to convert avi to flv</a><br /> <a href="http://www.mediaconverter.biz/guide/convert-avi-to-mp3.html">How to convert avi to mp3</a><br />
on Jan 24, 2011 | Computers & Internet
Transfer of avi file from nikon S52 to adobe premier pro.
Problem solved!
Convert the avi file from Nikon S52 to .mpeg1
Premier accepts this format. The file has to be renderd before it can be used in Premier. Files can be editted in Premier.
Aug 26, 2009 | Nikon COOLPIX S52 Digital Camera
How do I convert AVI files to MP4 files using Premiere Elements 4
just try
  1. quick vedio converter to do this
  2. quick media converter
you can download these software for free from
www.freedownloads.com
Apr 23, 2009 | Adobe Premiere Elements 4
Tip
Converting Movies to Psp Format
Hey again, this is a real quick guide for anyone interested to get a movie onto there PSP without all the fluff I have seen elsewhere. I just watched Aftica the Serengeti on my PSP and here's is the lowdown.
Movie - approx 40 minutes - DVD.
Saved to hard drive - 2.6Gig - using DVD.
Decryptor (free program) try Google.
Transferred to AVI format - 377MB - using Super DVD Ripper (9 FREE trial uses) then you must buy.
Transferred to MP4 - 37MB - using the (basically free) Image Convertor 2.
Average movie breakdown - using above as a guide only.
So i'm guessing the average movie may be 4.5Gig for example saved to 800MB.
CONVERTED TO 70-80MB.
OK, use DVD Decryptor to save the movie to your hard drive eg. c:\africa (it will save it for you as described). When completed find the folder c:\africa on your computer and find the vob file in that folder - generally the largest one and right click and play it with your dvd program to see what part it is. If it's the correct movie part you now know that's the one you need.
Once you have located the vob file you want to transfer open DVD Ripper and go to wizard icon. There you will see an icon of VOB to AVI button. Click it and then it will ask to locate the file. Locate the file and click it. It will SCAN THE FILE (just wait till that finishes) a parameter box opens next and just click the arrow. It then askes to choose output file, click the file icon and locate the correct fob file. It then askes for file compression - choose microsoft windows media and then click ok then press the start button. It will now convert the vob into avi format.
(there are also other options ie:dvd to avi etc.) I have only used the vob to avi for this test.
After DVD ripper has transferred the file it will save it to the same folder as the original move was in eg: c:\africa\viteots. Open the file and you will now see an AVI icon containing the movie.
Make sure you PSP is on and in usb mode then Open Image Convertor 2 and press on movie / add to list. For this example I click on c:drive the found the folder Africa and opened it and there was my converted AVI file. Click the file press ok and it will be transferred to your PSP for viewing pleasure.
****Note**** I only converted one VOB file as that's all there was for this particular movie. If you have more then one vob file you may need to try the dvd to avi when you rip. This is just a guide i worked out to compress dvd into the smallest possible file so you can get value out of a 512 card.
QUOTE:
Http://www.crazyhatsoftware.com/imageconverter2.1.exe
Image Converter 2.1 *** translated to ENG.
on Jan 20, 2010 | Computers & Internet
Hi. I use a program called Tevion PVR Plus to convert AVI files to Mpegs for TV viewing, but I've a problem for which I've been unable to find a solution. I hope you can help. The problem is that the...
you might be able o remove it by running the movie in windows movie maker
you might be able to remove it in there i know i have done some work with it and if you know how i am sure you can
hope this helps you out have a great day
Nov 21, 2008 | Computers & Internet
My PS3 will only play random .avi format video files using it as a media server
look in the programe menu on the ps3 and see if it set to only setin one file format amd change to all to play
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Compressing Files
Well compression software will not do the trick since you have only 1 file.compression software works when you have so many files .......according to your need ,you can only use video converter to convert the file...I do use a video converter name Total Video Converter for converting .vob files and mpg files to avi .....so it convert into 1/2 the size it occupies before converting.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Computers & Internet
Converting files
Jan 07, 2008 | Trekstor i.Beat Motion Digital Media...
Open Questions:
Computers & Internet Logo
19 people viewed this question
Alun Cox
