SOURCE: transfer my music and fotos from LG U880 to the new memory card
Solved it by copying all photos onto new card and the music but the pc cannot read the music so I have freed some memory but its not great
SOURCE: hello i have a micro sd
Hello
It happens to everyone. You delete a picture or accidentally format a
memory card that should not have been deleted/formatted. Luckily there
is a way to recover you data if you have not used the drive since losing
the data.
To start , download Disc digger from the following link :
Diskdigger
This program is freeware but donations to the developer are encouraged to help maintain and improve the program.
After
the program has finished downloading , simply unzip it and run it (no
installation). If you do not have a program to unzip it , CLICK HERE to download winrar.
Make
sure that your memory card is connected to your computer either via the
camera or preferably via a external card reading unit.
Now , select your memory card from the list when you open the program and then click next.
Now , for accidentally deleted files , select "dig deep"
For a formatted card/drive select "dig deeper"
Now select the file types you would like to recover on the next page and then select next.
The program will now start searching for viable files of the type you selected.
Files
that are found are displayed on the left of the window. Once the scan
completes , select all the files found and click the save pictures
button.
Now select a file other than the memory card to save the recovered files and select OK.
The
files will now be written to your hard drive and can be viewed on the
location chosen. Unfortunately all meta data and names of files are lost
because of the format , but at least the picture can be recovered which
is the important part anyways.
If you restored a file which was accidentally deleted , the file name and meta data will be restored.
Kind regards
Andrea
SOURCE: ne magu ctavet foto iz SD Card
Try downloading and reinstalling the card reader drivers. Get online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Card Reader drivers. If
that fails, you can alway purchase a multi format card reader from
Tiger Direct for less than $15. It plugs into one of your usb ports. http://www.tigerdirect.com When
the site comes up just type SD Card Reader in the search box at the top
of the page and Press GO. Sort the returned results Price Low to High. If
your camera came with a cable that you can plug into the usb port then
you can use that without taking the card out of the camera. Just plug
the cable into the camera and into the usb port of the computer, then
turn the camera on. The computer will recognize the device, install the
drivers and you can navigate thru the camera folders to find your
pictures.
SOURCE: how to transfer from my phone to sd card
I know you can use a computer if you have a card reader and a cable for your phone.
