Refrigerators Logo
l
lynn howard Posted on Jun 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Frigidaire side by side and the fridge side is flashing h1 and beeping
David Del Polito
Level 2:
Habit-Forming:
New Friend:
  • Expert 44 Answers
  • Posted on Jun 20, 2019
David Del Polito
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
44
Questions
0
Helped
19700
Points
108
H1 means the refrigerator or freezer side is to warm
Are the controls set properly?
Is the rear wall of the freezer full of snow?
Is the outside edge of the refrigerator warm or hot to the touch?
3 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jan 27, 2008
SOURCE: Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Mar 05, 2013
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire FGHS2644KF. Fridge just died. Flash code of 5YCF.
    Hello erintu81 - SY CF typically indicates that the refrigerator has detected a communication failure after power up. The wiring between the main control board and user interface board will need to be accurately diagnosis. Depending on the results either or will need replacing. At this point, I strongly recommend connecting a professional to move forward accurately and to properly assist with the repair(s).
    iam6fan
    Chris Huff
    • 6289 Answers
    • Posted on Oct 05, 2018
    SOURCE: My side by side frigidaire was giving me a H1 code so i unplugged it for 3 days and as soon as i plugged it back in it gave me the H1 code. How do i fix this problem?
    HI error means unit has detected temps are too high in either fridge or freezer. Since you’ve already unplugged it and code came back, you’ll have to determine what’s causing the temperature problems
    Frigidaire freezer has H1 error and is beeping and will not freeze
    Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
    Frigidaire side by side refrigerator/freezer has h1 flashing on refrig. side
    H1 is temperature detected as too warm. Is compressor running? Are evaporator and condenser fans running? Is there frost build up on inside back wall of freezer?
    We took delivery today of a new Frigidaire side/side. It has been on and has good in it for about 7 hrs. Both the Freezer and Refrigerator temps are flashing H1, but no beeping. What does this mean?
    the codes will be in the user manual that you got with the new fridges
    If you misplaced that publication , call the service agent and discuss what is wrong
    Side by side fridgidare wont stop beeping and showing H1, freezer door was cracked all night and our ac was out, tried to unplug and reset still nothing???
    Hey Nikkie, I appreciate your post!
    I see that your Frigidaire refrigerator is beeping and displaying the error code of "H1". An "H1" error code means that this is a high temperature within the refrigerator. Since the door was left open all night the refrigerator is registering there is a high temperature. I would suggest keeping the door closed and allowing the refrigerator to get back to the correct temperature. This may take anywhere from 24 to 36 hours for the temperature to stabilize. Hopefully this information is helpful to you. -Matt
    1helpful
    2answers
    H 1 flashing Frigidaire side by side
    I appreciate your post, Sharon!
    From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
    1helpful
    5helpful
    2answers
    Fridgeaire error code H1
    Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
    Frigidaire alarm for fridge keeps beeping
    I would try switching the breaker. That will probably work.
    Top Frigidaire Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
