Fan is broken so overheats. Same is happening with mine just need to fix fan I believe. I used it with a a office fan on top and it worked a lot longer.
Hi, Your problem is in your system protection unit if it works normal there is a problem with your amplifier system. To check that you need voltmeter connect the test probe on the speaker common line and the other to the speaker output before the protection relay. The voltage should be near to zero. but if more than that one of your power transistor or IC is dead.
