My D-link router (DIR-625) works fine when connected via ethernet but the wifi light is not coming on and the device info page says 'init failed' for the wireless radio. any suggestions?
If the wifi light is off its a sign that there's something wrong with it, so the first thing you can do here is to reset the router, To reset it press and hold the reset button of the router for 30 seconds and then power off the router for 10 seconds....
It is not going to work. Both wifi and ethernet are for internet connection only. Ethernet is much faster than wifi. Also there is possibility to damage tv by plugging ethernet cable which is connected device using POE (power over ethernet). You need to connect your dvr via hdmi, component or composite cable
have you got two dhcp servers running ?
turn off dhcp server in wireless router
and use the one in the Thomson TWG850-4 Residential Voice Gateway.
make sure ip address in wireless router is different to the Thomson TWG850-4 Residential Voice Gateway. make it one higher on last digit of ip address
make sure dhcp does not lease out this ip address.
If the printer is a network printer connected via wifi or via ethernet you should be able to add it on your network. If the printer is connected via usb port you will need to have a router that has a usb port and is able to add it on your network. If the printer is lan (ethernet or wifi) you plug it and search in printer installation for a network printer. To easier step you may want also to reserve to the printer a fix ip address and a network name. For further information you may want to follow producers instructions. If you don't have the manual you should be able to download it from producers website
You will need to talk to the IT lead at your job to see if he has given you proper allowances to access the VPN server. You also may want to check the errors or prompts screens that the the PC is giving this will tell you what the next step is. Please provide more information as to you issue your issue is not complete as to what you are experiencing for your VPN connection. 2. check the VPN configuration in your PC also there may be a firewall issue here that is not allowing you to connect.
You will need to check the wireless settings of the router.make sure that the DHCP server is enabled on the router. is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router. Click here for step by step instructions
You setup the router with the Ethernet cable always plugged in.. UNTIL you are finished configuring through the Ethernet cable via your browser. Once WiFi SSID & passwords WEP/WAP has been finished, AND you had another WiFi card in that PC the Ethernet cable was also connected to... well, THEN, I guess THEN, you may be able to disconnect the router from PC & then connect it again Wirelessly. But whats the point? But until then you won't find your router ON the Ethernet port, it would then be trough the WiFi adapter.. and that would have to be activated to work. Hope this clears things up
