Computers & Internet Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Using bluetooth on msi u90 HELP PLSE
I cant get my bluetooth to work on my msi u90 the user manual said push fn and f11 but that only switches off the wireless someone help please
Anonymous
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on Nov 27, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
84813
Points
112
U90/U100 - FN+F11, Multi-press switch, Green LED - Wireless is on, Blue LED - Blue Tooth is on, Green & Blue LED, both are on.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
16146
Points
26
You are insert the bluetooth cd and install bluetooth softwear
  • Anonymous Aug 09, 2009
    you are insert the bluetooth cd and install bluetooth softwear
1helpful
2answers
I have a netbook MSI U130 and the wireless function is unable to activate using the Fn+F11 is there a way to set it on manually? I'am clueless because I already run the recovery console to fix the...
I know you said that you have pressed the F1/F11 keys but first turn off your firewall as this may be blocking it then Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the 3G/ Wireless LAN/ Bluetooth
I hope this helps with your problem
2helpful
How do i turn on my wireless on msi u130?
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
1helpful
Hi please could you tell me how to connect my msi netbook to a bt hub wirelessly thank you
just switch on the bluetooth by pressing Fn+F11, blue light on the netbook would glow, press fn+f11 again if it doesnt work
I cant install my bluetooth in msi u100
Not all MSI Winds were sold with bluetooth. If bluetooth doesn't switch via fn + f11 then the hardware isn't present even if the software is installed.
4helpful
How do i switch on wireless on msi u90 notebook
Hello, You can put on your wireless on your MSI U90 notebook by pressing on the fn key and function key (F11). I hope this solution is helpful. Have a wonderful day.
8helpful
Cant get my wireless connection to work not sure
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
1helpful
2answers
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
4answers
How do I switch the bluetooth on on my U90?
it should have a button on your machine. locate it on the side and switch it on.
No user manual with new little MSI netbook. Need to know how to enable wireless network. Is there a switch or key combination?
Try this:
FN+F11 turns wifi/bluetooth on/off
Look at the LEDs on the front, namely the left most two.
No Blue + No Green = All wireless modes off
No Blue + Green = Bluetooth Off, WiFi On
Blue + No Green = Bluetooth On, Wifi Off
Blue + Green = Both Bluetooth and WiFi on
Press Fn+F11 to switch between each mode in turn in the order above.
Configure your wifi access with whatever tool you prefer. Some use the built-in windows wireless network , others use the realtek one. Use whatever works for you. (personally, I use the windows one).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Grand Canyon Tech
Grand Canyon Tech
