How to get the power steering pump off the pulley /dodger caravan 2001
The procedure to remove
the power steering pulley out of the 1999 dodge caravan engine is as
follows:----
· First
disconnect the black, negative cable from the battery.
· Then Take off the
windshield wiper module.
· Raise the front of
the vehicle using a jack.
· Then from
underneath the vehicle remove the drive belt splash shield .
· Locate the power
steering pump bracket and--working from underneath the car--loosen the through
bolt; then remove the pressure hose routing bracket.
· Place a catch pan
on the floor, underneath the power steering pump fluid reservoir, and siphon as
much steering fluid from the tank; then remove the pressure and fluid supply
hoses from the pump.
· Take off the rear
pump mounting bolt and front mounting bolts through the pulley. Make sure to
grab and keep the spacer located between the pump and mounting bracket once you
remove the bolts.
· Take the pump and
pulley assembly over the aluminum bracket and out of the engine.
Reinstall all parts and
new pulley in reverse.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
