The trigger has a silver thing can i get a manuel
SOURCE: Ryobi string trimmer -weed eater pull cord hangs out wont start
What model number is your Ryobi?
SOURCE: Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Testimonial: "Thank you! Just what I needed."
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
