Navigator Software
The Navigator software is launched whenever your machine is connected to the computer and the machine is on. This software communicates with the machine.
If this is not installed follow these steps;
Link to manual is below;
http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Smart_300E-manual-EN.pdf
Software link below;
http://www.pfaff.com/en-US/Support-and-Updates/Complimentary-Software
If this was helpful please click the helpful button.
SOURCE: What do I do if my computer still will not recognize the machine and software?
Hi - What version of the File Assistant are you trying to run? The original version did not communicate and a subsequent version fixed this. It could also be a com port setting or a few other things.
If you email me your phone number, I'd be happy to call and try to walk you through some things to get it working. Takes too long to write and too many trouble-shooting steps that change from scenario to scenario to write it all here!
I worked for Pfaff for 10 years doing just these kinds of things and would be more than happy to try to help you out.
Look forward to hearing from you,
Kim
SOURCE: can't open Pfaff Select 3.0 Sewing Machine to fix timing
I found an electric drill with a hex bit and that did the trick!
SOURCE: no communication between pfaff 7570 and computer
It sounds like you have it configured properly if you have the little machine and computer appearing on the display screen. I had this problem too in the beginning, file assistant doesn't use the files for the 7570 its only for some of the newer machines, use Vip customize to send the design to the machine from the file drop down menu. Hope this helps.
SOURCE: I just inherited a Pfaff 139. Can you tell me
Hi! Congratulations! I just read a great review of your machine at http://sewing.patternreview.com/cgi-bin/sm/readsmreview.pl. One of the things the reviewer noted is that the 139 wasn't designed by Pfaff. It was designed by another sewing machine company (the GZ in your serial number) that Pfaff had bought. The machine dates to the 1950s.
Statewide sewing (http://www.statewidesewing.com/#Accessories) has a great selection of belts.
Hope this helps!
Happy Sewing
Robbie
SOURCE: WHERE CAN I FIND FREE DOWNLOAD MANUAL FOR PFAFF
Go to http://safemanuals.com/user-guide-instructions-owner-manual/PFAFF/SMART%20200C-_E. For giving your opinion on the machine, you can download the manual, no viruses, for free. I've tested it and thoroughly ran a virus scan already.
