I have cable network home connecting with a cable modem Scientific Atlanta. I have three more pcs at home two are connecting with cables and one is a wireless. I have an adsl modem zyxel prestige 600 and I want use it distribute the data coming from the cable modem, and expecially use it through wireless since Cable Modem isn't a wireless modem.. How can I do it? I connected the cables and I established a network but cannot connect to the net. Do I have to make some adjustment in Zyxel modem to make it working? I would be glad if I had some help. Thank you.
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
