How to fix a secondary drain problem on a rhll-hm6024ja
Hi Ken, Usually an ac repair man will take the front cover off the main AC coil. Inside,Below the you'll see the main drain pan. depending on how the drain is plumbed, the main drain should be to the left or right, corner. If you have a small compressor, you can blow out the line. If not, a electrical snake, or wire coat hanger will suffice. Be patient and go slow. Make sure you put a small hook on the end you'll put in the line. Move forward and backwards every two inches. Assuming you have two lines ( one for primary, one for secondary,) You should have a trap on the line. when you get to that portion take it slow. chances are your cloge is in this area of the line.
