SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: MIcrowave light and turntable are working, but food comes out cold
I suspect the magnetron or high voltage transformer, and either part's cost or labor would probably be about the same as the cost of a new comparable unit.
SOURCE: Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find
helpful exploded view diagrams and order
parts by
entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
SOURCE: microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Remove your glass turntable cooking tray from your microwave. Gently
wash with warm soapy water to remove any debris. Next remove the
turntable guide and clean it in the same manner, with warm soapy water.
Pay particular attention to the turntable rollers. There could be
spilled food particles caught in the rollers, hindering the rollers'
movement. Also, gently cleanse the internal cavity of your microwave,
paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely
clean and dry, return the parts to your microwave. First place the
turntable guide on the bottom of the microwave. There should be a
circular groove in the bottom of the microwave cavity keeping the
turntable guide in place. Follow the guide with the turntable cooking
tray. Carefully place the glass tray over the turntable guide and onto
the drive bushing. The drive bushing should fit neatly into the grooves
on the bottom of your glass cooking tray. It may take some adjusting
before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in
order to determine whether this has solved your problem. DO NOT run
your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's
turntable tray. There may be some debris blocking the tray's range of
motion. Clean away any blockage you find, and then test your microwave
to see if this has cleared up the problem. DO NOT run your microwave
with nothing in it.
However, if upon your
inspection, you notice that the plastic drive bushing below the
turntable tray is worn and/or broken, you will need to have the bushing
replaced. Consult with a certified and experienced appliance repair
technician. Replacing a drive bushing is a lengthy and involved process
that the average layman should not perform.
Good luck.
